Joined: 6/2/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Tucson, AZ
The black rubber hose gets wet from a large leak somewhere higher up on the left side of the tub (on the outside of the tub). Water is getting into the tub. Can't find a diagram for what is up there or any indication what is causing this leak. The common reasons listed for leaks are seemingly not my problem. While I was checking into this I noticed the door gasket has a hole right where there is an indentation for a screw in the gasket grove in the tub... seems like those indentations create stress (like a hernia?). This is an 18 yo old dishwasher that never gave me any problems before. I cleaned the gasket and put it in backwards... so now the tear faces the screw and the gasket should again provide a good seal. Time will tell if that works but saved about $75 and it was not leaking from there before. Update: I'm a disabled 75 yo woman but I managed to pull the dishwasher out and see that water is leaking from a split in t upper curve of the rubber tube going into the tub. Of course a replacement tube is no longer made. LOL That's capitalism: fails always due to some cheap part that does not last and can't be replaced. Edited by user Friday, June 3, 2022 8:41:51 AM(UTC)
| Reason: Not specified
