Unit coils froze up & tested defrost heater and it was 32 OHM. Is that the spec? I ask because when I tested the defrost heater in the fresh food section that was 82 ohm. Thinking the heater in the freezer is going bad or not enough resistance to work properly
Suggestions or comments are appreciated
