Hello, I have a maytag Mvwx655dw. Washer is about 4 years old. It leaks a little water + oil during spinning. No noise or anything out of the ordinary (like bearing/gear noise). I can see the dirty water on the motor pulley underneath. If it was just the oil, then I assume it would have all leaked out by now from the transmission. But there is water oil mixture. So my noob guess is a seal is letting through the water which then gets to the transmission gears and spills out with it. The tub seal is the only thing I could really find as a replacement part to buy. Could that be causing this problem or does this require a whole new transmission? Thank you for the help Edited by user Monday, April 11, 2022 1:16:33 PM(UTC)
| Reason: Not specified
