For some reason out of the blue, our ge dishwasher trips gcfi when you push start button. Vacuum runs on circuit without tripping. Diagnostics returns a 6 but there is no ge code of 6. The start button flashes nonstop and regularly chimes for a short while. Can cycle through all the settings but only trips when start button is pushed and door is shut. Tried with sump disconnected and still happened. I see no water leakage anywhere. Model # GDF630PGMWW Update 2/6/22: Plugged dishwasher into non-GFCI outlet and was able to run diagnostics. Got nF code but nowhere does any site list nF error code for GE dishwashers that I can find. Assumed it meant no fill but not sure how to fix. Thanks. Edited by user Sunday, February 6, 2022 7:29:24 AM(UTC)
| Reason: Not specified
