AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Lg front load washing machine excess drum wobble
Washer stops mid cycle with error code IE. we changed the door latch, but the problem persists. I noticed today a lot of wobbling vibration when spinning. I steadied the case and it allowed the washer to shift to spin fast enough to finish the cycle. What is the most likely problem: a broken spider, a spring is loose or broken or a problem w the counter weights?
Washer Repair
