Model Number: ETW4400WQ1 top load Brand: Whirlpool Age: More than 10 years
I have repaired this machine many times even as far as rebuilding the transmission. The current problem is that on the agitate cycle, the bottom agitator rotates only anticlockwise, and when it should reverse it just gives a scraping snarl Everything's else seems to work fine. Can you suggest what it might be?
Michael
Thanks for your reply. Actually I recently rebuilt with a new neutral drain kit and a new gear rack (which had cracked). I was careful to reassemble correctly.
