Need help
#1 Posted : Wednesday, December 29, 2021 3:31:30 AM(UTC)
Guest
Groups:
The unit was in the rinse cycle but the drum was not spinning. The pump was flushing water through the top compartment where you add rinse fluid. the unit was continuing to cycle as you could hear the clinks and clunks as the unit was going through its steps but the drum never would spin. Water occasionally would be pumped out the drain. water continuously was being pumped through the top compartment. There was a Fe code but this web site does not have error codes for an LG washer? So not sure which video to watch,
The "Rotor Position Sensor Switch for LG WM0532HW Pumps but will not spin" sounds like what I have but not sure. Any suggestions. I might order the switch and take a chance. There are just no good ways to find a decent repair person in this area.
