Had same code “do” Door Open . Several years ago. The door latch mount bar was bent in from repeated door slamming . Flexed it back out, was ok 6-8 months . Then same code .
I sprayed contact deoxidizer in the switches , problem fixed since then . Last week, same do code .
Sprayed the switches , nothing , flexed the mount bar, nothing .
I finally replaced the latch/switch with a new factory part and still the same do code .
Anyone have any suggestions what I can do next over the weekend ? Thanks in advance .
