Groups: Guests
Just stopped making ice one day. Water pressure good. Fills with water fine but won't eject. The optics check out ok; steady red when ice bin detector is closed. Red light goes off when freezer door is closed. I thought it was the ice maker itself and replaced it, only to have the same problem with the new one. Edited by user Tuesday, December 21, 2021 3:03:14 PM(UTC)
| Reason: Not specified
Groups: Guests
Not much help here, is there?
With the water off, and the cycle running, it should try and first heat the tray and then the ejector fingers should rotate, is this happening?
Groups: Guests
Thank you for the reply. The fingers don't rotate after filling and freezing.
Groups: Guests
Groups: Guests
Well... that was anticlimactic.
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Groups: Guests
Thanks, TG.
The sensor appears to be working as designed, but I'll run the jumper wire on the plug and see if it cycles.
Groups: Guests
Well... I jumped the pins on the sensor board, left it for 48 hours, and...
Nothing.
