I was given the range no manuals or meat probe. The probe light blinks for the lower oven. I tried removing the plug out of the range. Tested each wire to ground and wire to wire and no shorts. I did not unplug the harness from the board and did not get any ohm reading wire to wire. Any ideas or am I going to need to replace board.
