ljramos
#1 Posted : Saturday, November 7, 2009 7:15:50 AM(UTC)
ljramos
The dryer dashboard has an erratic behavior it sometimes the buttons activate with a normal press but sometimes it takes several presses and or pressing all the buttons randomly until the lights gets turn on. Is this an idication of a faulty dashboard circuit board or maybe looses connections inside the wiring section. How do i dismantled this unit for troubleshoot
#2 Posted : Sunday, November 8, 2009 4:39:40 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208546206.pdf
Here is a manual. Note I am not sure this is your unit but it should help getting it open.
https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdf
Try runnig the diagnostics.
Check the keypad outputs with a meter. If it checks out OK then the control board is most likely the problem. Note that this is always a bit of a crap shoot as to which whether it is the keypad or the control board.
You could also try the following:
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
ljramos
#3 Posted : Saturday, November 14, 2009 8:48:21 AM(UTC)
ljramos
I was able to enter diagnostics mode. As soon it is in this mode the panel start beeping and the second digit of the timer blinks. I cant find why this happens or solution on the the tech sheets that you posted on the reply. Any clues? thanks
#4 Posted : Sunday, November 15, 2009 1:46:26 AM(UTC)
Does sound like the control board is shot.
