JMM12
#1 Posted : Friday, July 30, 2021 4:52:44 AM(UTC)
JMM12
WED9400sw running very hot
error code f23 and f25 flash in diagnostic mode \and for short time a 72(or73) code flashed
replaced outlet thermistor and fuse.(checked old fuse and had ~12-14K ohms(similar to new one))
still flashing same codes
checked inlet thermister and sensor(lg terminal) are in continuity and small plug terminals show ~50k ohms (which I think is ok)
unsure about replacing inlet for ~$50 as it appears good, like outlet thermistor
wondering if it is the board
checked P4 3 vs p36 wires and measure ~12Kand p8-3 vs p9-1 were similar
what to do next?
