AC
#1 Posted : Sunday, May 9, 2021 9:36:35 AM(UTC)
Guest
Groups:
Hi recently my maxx ice machine has stopped dropping water from the top into the vertical ice tray to start the harvesting process. It makes noises and the trough fills up but the water drip has stopped working. I just pulled out the fuse and the relay and both seem to be in good working order. The relay looks clean, no burn marks nor does it make a rattle sound when shaking. The fuse as well, no burn marks and the wire inside looks intact. That’s about the extent of what I’m able to remove and test. Any thoughts or ideas?
