Joined: 3/18/2021(UTC) Posts: 0  Location: california
My GE Refrigerator GSS25GSHJCSS stopped dispensing water on my wife when i was at work. "Firefighter, so im gone for a few days at a time. " She also informed me a few hours later that the vegetable and salad draws both froze over.
So i assumed the system had frozen over had her unplug it and i ordered a new Heater/defroster and a thermostat and tossed those in, in hopes that it would fix the issue.
Well after having it plugged in for the last 14 hours i have been able to look it over my self, rather then getting second hand information from my wife.
My issue is still not resolved. The water was dispensing when i plugged it back in but has stopped after the freezer has dropped past freezing temps. " so im assuming the line is freezing over? "
I also noticed it seems the fridge is struggling to regulate its temps. freezer set to 0 and fridge is at 37. but seems like its holding/reading at -1/41.
When opening the fridge up i noticed i had no ice and felt in the tray and there is water in the ice tray but it is not freezing into ice and does not seem very cold in the ice tray area but just below in the main department of that freezer seems plenty cold and has frozen drops around the area.
The fridge looks like both produce drawers have frost on the front of the drawers. the rest of the fridge does not feel very cold?
The water dispenser seems to work if i let everything defrost but then will stop after the freezer gets below a certain temp.
Does anyone have any input or opinions on what i can check/ replace to figure this out?
I believe this is only a 2018, so very disappointed in that its having issues already.
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
HOW TO REMOVE DISPENSER CONTROL BOARD
