Joined: 12/28/2020(UTC) Views messages in topic : 0 Location: St. Louis
I have a Viking dual fuel range. It’s about 3 years old. The electric oven started having the following problem. When you turn the oven on, for a few moments the oven light comes on blue(normal) but then the self clean light comes on blue and the oven light starts flashing. The oven doesn’t heat. I read online the suggestion to turn off the breaker to reset the electronics, but that had no effect. Any ideas?
Did you ever figure this out? I'm having the same issue.
