I have been getting the suds F71 error and am trying to install a new hub on my Model #11027032602 Kenmore Elite top loading washer. The washer is 14 years old. I see that the splines on the shaft are warn at the bottom where the driver hub goes. The inner teeth on the old hub are warn -- but the teeth to connect the two hubs together are fine. Should I use JD weld to help keep the hub driver affixed to the shaft without spinning around it? Edited by user Saturday, December 19, 2020 5:49:05 AM(UTC)
| Reason: Not specified
