Went to get water from the fridge and the dispense did not work. The panel appears to reset when the paddle is pushed.
Example: the paddle is pushed for water, the panel goes dim, the courtesy light does not come on, then the Control Panel lights back up after the paddle is released.
Without pushing the paddle, the control panel works fine. Oddly, i pulled the courtesy light on the dispenser, tried to get water and it worked. I put the bulb back in and it worked for a period, then stopped again. I have since removed the light bulb, and it seems to be working fine.
Not sure if the problem is really in the light, or the paddle switch.
All other functions of the fridge are working fine.
GE Profile Side by Side Model: DSD26DHWC BG
