My Maytag model MHWE201YW00 will not complete a cycle unless its empty. If I put in as little as 1 pair of pants it just won't spin. I would suspect the water level switch or door latch as recommended if it weren't for the fact it operates normally when empty. I haves cleaned the drain and do know that it does empty all the water when its supposed to. No obstructions in the drain system. It has functioned for 5 or 6 years in its current location.
