Help with Off Refrigerator Temperature Electrolux EI23CS55GS1 Our Second refrigerator started to act up. It is IQ-TOUCH Version B
Had heating coil failed last week ( tested infinity ) replaced it, together with defrost sens. Now freezer works Freezer Thermistor reports 0 to -1degree on test - good Ambient Thermistor - 70F - good
Test 22 - Damper Test passes I can feel cold air esp if evaporator fan on High Test 15 - ok, I can see the evaporator fan going low and high
But refrigerator not working so good. Set to 35F FF Thermistor reports aS 40F - 41F Meat drawer Thermistor reports as 40F Salads going bad in one day.
IR thermometer reports 44F What could be wrong?
