AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
596.79322010 Kenmore French Door bottom mount - Replaced lower evaporator but still issues
Started with warm refrigerator - both freezer and fridge. Tech came and after a weeks wait - replaced the lower evaporator coil assembly Since then fridge only held temperature for couple of days. - Tech refilled gas, but again back to not holding temperature. - Still cools but Freezer at 12 and Fridge at 54 ..not 0 and 39. - Ice trays hold ice in the freezer, but frozen food is not ice cold. - Fan is working Opened the back panel. Lots of solid ice buildup in the right corner side - Absolutely, no ice in/around the drain hole this time or the bottom of coils Used hair dryer to melt the ice. Had the freezer ON for 4hrs and re-checked the coils- Again build up of ice on the right top capillary? What was missed or can it be fixed? [img=https://imgur.com/1FBOK4n]Kenmore Double Door Fridge not cooling enough[/img] [img=https://hosting.photobucket.com/images/i/karm]Kenmore Fridge[/img] Edited by user Monday, October 5, 2020 9:30:31 AM(UTC)
| Reason: Not specified
