Hi,
I have an 11 year old Blomberg DW36140 that stops mid-cycle - it seems to fill with water, then stops before the wash is about to begin as if the door has opened. When I push the door in (closed), it starts up again. This requires a few tries for it to “stick.” Then when the water drains and the next cycle is about to begin, the same thing happens and I have to push the door closed to get it to continue washing.
I have replaced the door latch thinking that was the problem, but no change.
Any other ideas?
Thank you in advance
