i have a older maytag bravio washer wtw6600sg0 it keeps throwing a UL error unbalanced load at around the 9 minute mark left in cycle, then goes back to 13 minutes to try and even out load. i have replaced the 4-suspension rods. no luck then i inspected stator motor , whis has many cracks. so i replaced stator and mtor rotor cover with o used one in very good condition, first few loads were ok, now getting same unbalanced load issue, cannot advance to spin cycle. do i need to replace suspension rods again, since the new ones were on for a few monthsuntil i inspected stator motor, the rods seem to have play in them sideways, but ok horizontally. pls help could it be something else. thanx
