Jjacquard
#1 Posted : Wednesday, July 8, 2020 11:49:50 AM(UTC)
Jjacquard
Canada
So my Samsung VRT front load model WF45N6300AV/A5 has an issue where it is always leaving clothes soaked at the end of the cycle. For some reason it will finish the spin cycle and right before the cycle ends it will start adding water and then shut off as if the cycle is done. Sometimes when this happens it will overflow out of the airflow hose at the top of the drum. I have removed the pump and drain hose and checked for clogs and took a look at the pump impeller blades and they all seem fine and unobstructed. I feel like maybe the water level sensor could be faulty or maybe I am missing something? Could the drain pump be going bad and not pumping out all the water it should be? The drain hose is installed correctly into the drain pipe and is a the correct height. Any insight would be helpful
