supra-raleigh
#1 Posted : Tuesday, May 26, 2020 12:18:56 PM(UTC)
supra-raleigh
The Kickstart capacitor bubbles out fluid when I press the contactor button/plunger. I priced an identical new capacitor and they are not cheap. The cheapest one I saw was around $180. The part# is 5162718 or KSTS324 or HC95DE042
324-356MFD
330VAC
I found a cheaper one on the Grainger website for alot less.
But, the specs are not identical. The specs are:
216-259MFD
330VAC
Made by Packard #44ZU51 $17.20 This one has a resistor soldered into the terminals like the Kickstart Capacitor.
I also found one with the following specs:
DAYTON
Round Motor Start Capacitor,300-360 Microfarad Rating,330VAC Voltage Item # 2MEP7 $55.50. This one does not have a resistor soldered into the terminals.
Can one of these or some other capacitor be used as an alternative to the original Kickstart capacitor?
Thanks very much
Edited by user Tuesday, May 26, 2020 2:00:15 PM(UTC)  | Reason: Not specified
supra-raleigh
#2 Posted : Tuesday, May 26, 2020 1:39:06 PM(UTC)
supra-raleigh
Also, I have searched for the relay for the kit, but I can't find it other than purchasing the Kickstart kit #HC95DA401
It is a 5-2-1 relay. Can I just get another 5-2-1 relay from some other kit? I ask because other kits I see have a 5-2-1 relay for much cheaper. So, in other words I would like to replace the capacitor with an alternative to the expensive Kickstart one and source the relay elsewhere for cheaper. Thanks for any advice.
supra-raleigh
#3 Posted : Tuesday, May 26, 2020 2:37:31 PM(UTC)
supra-raleigh
One more thing... The COMM STATUS amber light is blinking. It blinks 6 times and pauses and then repeats.
Edited by user Tuesday, May 26, 2020 5:19:22 PM(UTC)  | Reason: Not specified
supra-raleigh
#4 Posted : Wednesday, May 27, 2020 7:18:06 PM(UTC)
supra-raleigh
I fixed it with this:
5-2-1 Compressor Saver CSRU3 Hard Start Capacitor For 4-5 Tons.
