Joined: 3/30/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Ohio
The problems started with the washer not working when trying to use hot water. It would work fine if using only cold water. When trying to run a cycle with warm or hot water there was a buzzing sound that I tracked back the hot inlet solenoid. I went thru the diagnostics and it was F8E1, which I assumed a slow water fill since no hot water was coming into the tub. I ordered and replaced the fill valve. After putting it all back together it is doing the same thing as before, and the hot water solenoid is buzzing again. The only I can figure out is that the new full valve is bad. Need help diagnosing this.
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
Rule out bad solenoid by switching the power wire from the hot and cold solenoid. Run just a cold cycle, if you get the same issue (buzzing) on the cold valve it's a power/connection/wire/controlboard issue not a solenoid issue.
