AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer Not Heating even tough Fuse and Heating Element is good
Rank:: Member
I have a Kenmore Dryer Model #110.612020111. The blower fuse has continuity as does the heating element yet it will not heat. Any constructive thoughts? Is there something on the switch panel I should be testing? can't figure it out.
Thanks, Mick
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Have you checked continuity on both the thermostat and high limit thermostat on the heating element case? Have you checked continuity on the cycling thermostat on the fan side (the two large connectors) the two small connections are used to reduce the heat needed to cycle off.
Dryer Repair
