paulmarsA
#1 Posted : Friday, January 24, 2020 7:55:29 PM(UTC)
paulmarsA
Why is it needed? Ive only repaired a few dryers, but this looks like extra part. This dryer has the std High-Limit Thermostat, Operating Thermostat, and Thermal Fuse. However, it also has this Thermal Cut-Off Fuse. This Thermal Cut-Off fuse is located in the heater housing where it feeds the drum and looks more like a thermostat. Its also the most expensive part.
See attached diagram. ( https://imgur.com/a/Q3vVHeP )
#1 Thermal Cut-Off Fuse
#34 High-Limit Thermostat
#42 Operating Thermostat
#59 Thermal Fuse
kenmore 110.96281100
tks,
pa
paulmarsA
#2 Posted : Saturday, January 25, 2020 6:51:01 PM(UTC)
paulmarsA
Ive watched several troubleshooting videos for this specific model troubleshooting for no heat. Each video tested the High-Limit Thermostat, Operating Thermostat, Thermal Fuse, heating element. One of the videos tested the timer. None tested or even mentioned the Thermal Cut-Off Fuse.
paulmarsA
#3 Posted : Sunday, January 26, 2020 9:10:51 AM(UTC)
paulmarsA
Before I purchase new cut off, I decided to test the two thermostats:
one is marked L155-25F. it opens at 110°F.
the other L250-80F. it opens at 180°F.
Some sites say that number after the dash is +/- for opening temperature. Other sites say that is how much less the temp needs to be for closing. I dont know which sites are correct.
Thermal cut-off fuse keeps blowing (Dryer Repair)
by rpaul111 1/21/2018 3:14:57 PM(UTC)
Thermal Cut-off Fuse Keeps Blowing (Dryer Repair)
by tlhiv 10/22/2014 6:38:46 PM(UTC)
