Joined: 12/28/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Syracuse, NY
I have a Kenmore Quiet Guard Standard which is leaking from the lower left side. I have replaced the lower door seal and the main door seal (we had just moved in and I thought the main seal was just being cautious). I also checked the lower spray arm for cracks, found none, and replaced it to be sure, still slow leaking. Upon watching it during a cycle, there is an infrequent surge on the left side of the bottom door seal which goes up and over the pan and leaks off the hinge. The water surges through the small gap between the lower door seal and the side wall. Cannot figure out how to resolve this. Any thoughts would be appreciated. Thanks
Joined: 10/17/2023(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
Did you ever get this figured out? I'm seeing a similar issue.
