Hi - my Maytag Bravos washer won’t spin and is making a loud electronic type sound. Going to try to attach a video. We did unplug for several hours and plug back in and it’s still happening. The washer is currently full of clothes and water. I also tried removing lots of the clothes in case it was overloaded but that didn’t work either. It’s about 1.5 years old. I have a video of the noise but can’t figure out how to attach here if that’s possible.. Thanks!
We had the same problem, the machine works great, unitkl it would not spin. no alarms light, nothing. The plastic hub wore away the metal "teeth" gears on the shaft.
