AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
BOSCH SHE3AR55UC/07 starts, drains, fills and stops
I have a Bosch SHE3AR55UC/07. When I push the start button it drains, then it used to go to a short cycle where it made a "whirring" noise and then fills and runs. Now, instead of the"whirring noise" on step 2, it makes 2 short "squeaks", fills and then stops, lighting up the "CLEAN" light, but the dished are not clean and there is water in the bottom. The fix in this video used to work, but now it does not. I have replaced the control board, the drain pump and the inlet valve. What now? Thanks, Eric
How can I get the "error codes" from my dishwasher that does not have a display? Thanks, Eric
Dishwasher Repair
