Please help -- I posted on this once before with no responses. I keep getting the LF error during the rinse phase of most wash cycles. The error doesn't happen during initial fill or during the wash phase, only during the rinse phase. After pushing the power button twice to cancel and drain, I can switch to "Rinse and Spin" which will work fine. I have checked the hoses and the filter screens at the hose connections -- no problem there. I have not been able to determine a pattern as to which cycle and/or temp combination is causing the problem. HELP
