I have a Frigidaire FFHS2611LS0 side-by-side fridge/freezer. My icemaker only makes crushed ice currently. The internet suggested it was the solenoid that controls the ice mode, but I want to make sure first. I looked at the diagram for my model, but it doesn't quite match the switch behind the dispenser panel. I did switch two wires and was able to make the ice mode solenoid operate. I would assume that rules out the solenoid and that I need to replace the switch. Is there a way to test the switch to be sure? This is my switch, part #241679101 ![UserPostedImage](https://i.imgur.com/PgyPAId.jpg) ![UserPostedImage](https://i.imgur.com/VQfd2lh.png)
