I have an old whirlpool compactor i saved from old house that tore down. Got it home and plugged in . On start goes down but then freezes. After a while or if i turn wheel a little thwn on start will come back up. Motot is trying to reverse at boottom but then just wont. Gears and all look good can. When i put a log on bottom for it to hit appears to reverse fine but wont reverse without something in bottom. Since it just wines and stops then i can get it to go up again cant see or figure out what is not working? Advice?
Joined: 8/12/2019(UTC) Posts: 0  Location: New-Mexico
Hi, I had the same problem, in a few days it stopped even make any sounds. I found out that it would cost me $72 wirh two details and work, so I just googled and odered one from amazon, non-electric. $100 and I'm glad I did. I'll send you a link on the article I've found if I find the saved link Let me know how your story ended
Originally Posted by: WestaCay  Hi, I had the same problem, in a few days it stopped even make any sounds. I found out that it would cost me $72 wirh two details and work, so I just googled and odered one from amazon, non-electric. $100 and I'm glad I did. I'll send you a link on the article I've found if I find the saved link Let me know how your story ended Luckily I found it! https://pickadvisor.org/best-trash-compactors/There are few great model, but prieces range, so check them before deciding I own the 3rd btw Edited by user Monday, August 12, 2019 10:04:41 PM(UTC)
| Reason: Not specified
