AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't fill on wash cycle only -- GE GTWP2250d0ww
Joined: 1/4/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: California
Hi, all. My GE GTWP2250d0ww will not fill on the wash cycle only. It fills completely on the rinse cycle, but on the wash cycle stops at maybe 1/3 full.
The pressure switch tests good. No problem with the inlet valves and solenoids. Test mode showed nothing out of the ordinary. I turned it to activate the cold water valve and it filled it completely.
This washer is always set to Super load size and to Cold water only. It's worked great for years.
Anyone know what the problems is? Thanks in advance.
Matt
Washer Repair
