scully61
#1 Posted : Monday, November 19, 2018 5:44:51 AM(UTC)
scully61
I have a frigidaire/electrolux model LTF2140ES3 washer, it will not spin, I ran the self diagnostic tests and it gives me error code E43 Which says to replace control board, my question is: do they mean the motor control board or the main control board?
redeka
#2 Posted : Thursday, November 22, 2018 5:19:34 PM(UTC)
redeka
Canada
Error code E43
Condition: Control detects a problem with the door lock circuit
Check/Repair: Unplug the washer and check the wiring harness connections between the door lock assembly and the electronic control board. Reconnect any loose wires or replace the wire harness if damaged. If the wire connections are okay, the door lock assembly usually needs replacing. If you replace the door lock assembly and the problem continues, replace the electronic control board.
In this case, the mean the user control panel up top (the main control board)
