AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
LG Dryer DLG7188RM will not light burner when hot
Here is a video of the burner running when started from cold: https://drive.google.com/open?id...lJUHzIzDd1Sx6bW7xbLVy8uUIt starts and runs for 20 seconds or so, then cuts off. After about 90 seconds there is a loud click and the ignitor lights up again, but no gas so no flame. It continues this cycle where the ignitor glows but no gas until I turn it off. If I turn everything off and try again it will not burn, but if I wait 10-20 minutes it will start the burning once. I used a multimeter to check all the parts on the burner assembly (2 temp sensors, flame sensor, gas valve solenoids) and they all measure in range when disconnected. I am assuming it is temperature related, but bypassing the temperature sensors results in the same behavior. Is the flame sensor sensitive to heat? Is something else overheating? Thanks for any advice.
Dryer Repair
