Harley Monster
#1 Posted : Friday, May 11, 2018 5:45:59 PM(UTC)
Harley Monster
i have replaced the brake, tub bearing and seal and mounting stem. The repair went well; however, when i finished the outer tub in the front is too high and the top will not go down all the way. Before I tear it all apart again, do you know what is wrong? What i should look for? Have you seen this before?
This is on a Maytag LA712.
Harley Monster
#2 Posted : Monday, May 14, 2018 12:58:25 PM(UTC)
Harley Monster
I ended up taking the spin tub out, inspected the out tube seal from underneath the tub, inspected the stem and all looked normal. I reinstalled the spin tub, making certain it was centered as close as possible. After doing this the top fit down normally. I dry ran the new seals for the 3 minutes dry, then ran the washer and all cycles work normally.
Evidently when I first installed the spin tube it wasn't centered which caused the alignment problems. When installing the spin tub I recommend paying close attention to the centering of the spin tube.
