Does anyone know the limit temperature of the defrost/thermo switch ? Also the range ?
The heater works fine and has been modified with numerous copper wires going around the cal-rod and up into the evap core. I need to replace the switch and don't want to have to pull out the evap to undo all the copper wires.
Unfortunately I already threw away the old limit switch and did not look at the numbers on it before I did ... Yes I know. Dumb move on my part.
Jenn-Air refigerator MODEL # JCB2389GRS
