ice maker mold wont eject ice. the water fills the mold, it freezes, the ejector turns but cant eject the ice because the ice mold wont warm and release them. this is the second ice maker i've installed where this has happened. is this an ice maker problem or something else?
the refrigerator is a Frigidaire Gallery Professional and like the rest of the appliances i purchased from Frigidaire, it is a piece of garbage.
A part number for the ice maker you installed would be helpful.
Also the frigadares model number. :)
The ice maker part number is AP4299334.
The refrigerator model # is FPHC2399KF0 and the serial # is 4A91506812
I feel the same about the quality of frigadare. I'm not sure what's inside the new style ice maker, but the old ones had a thermal fuse in them that would fail. It's part number F11 on this diagram. Parts for Frigidaire FPHC2399KF0: Ice Maker Parts - AppliancePartsPros.comHave you checked the temperature of the freezer? It needs to be below ten degrees Fahrenheit, the closer it gets to zero the better. I ask because you've had more than one do the same thing.
i will check on the temperature when i am home. i looked online that particular part does not seem to be in stock. even if it was, is it something that a complete novice like myself could replace?
