tobloyd
#1 Posted : Saturday, December 30, 2017 9:47:59 AM(UTC)
tobloyd
A builder friend of mine gave me this rangetop. When I turn it on to high, the flames reach up to a foot high. It's more normal when I turn the knob lower though. Is this just the way Vikings are? It seems like a fire hazard to me.
Also, when I use the griddle function, The front panel of the unit becomes hot enough to cause a blistering burn if you touch it. (I put my meat thermometer on top and it read over 212°) again, is this normal? I guess I don't mind being careful not to touch it, but I suspect that that heat can't be good for the electronic parts inside of it
UserPostedImage
tobloyd
#2 Posted : Saturday, December 30, 2017 10:15:39 AM(UTC)
tobloyd
I get a gas delivery to my house(I assume this means propane?). Could it be that I need some kind of conversion to make this range work right on my gas?
tobloyd
#3 Posted : Monday, January 1, 2018 7:57:17 AM(UTC)
tobloyd
It just needed LP conversion nozzles.
Still not sure about the heat issue though. Is it normal?
