je00409
#1 Posted : 7 years ago
je00409
Entered the test mode and got the following error messages:
Er:20 Spin Cycle Terminated, No communication between control and inverter, Unbalance too high, check wire harness, check load
dr:08 Speedometer Failure, Damaged speedometer, check wire harness
dr:10 Power limiter switch off, too heavy load, mechanical friction, check oscillating system, check gasket, check load
dr:11 Voltage too low, weak power supply, check line voltage
Given the above, is this something that can be repaired and if so, what parts are needed?
Thank you
missie
#2 Posted : 7 years ago
missie
I have the exact same model and mine won't spin at all. Only error code is E20. SOOO frustrated!!!
je00409
#3 Posted : 7 years ago
je00409
It needed a motor and motor control board. I bought a new washer.
missie
#4 Posted : 7 years ago
missie
Thanks so much for the quick reply! I THINK my motor is ok- if I tested it correctly... so I guess I'll gamble on the control board. Thanks, again!
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 12 months ago
Samsung washer won't spin (Washer Repair)
by Guest 3 years ago
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 3 years ago
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4 years ago
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 5 years ago
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 6 years ago
Washer won't spin out. (Washer Repair)
by DJChad818 7 years ago
Washer won't spin (Washer Repair)
by Fingers123 7 years ago
Washer won't spin or agitate (Washer Repair)
by dhughes 8 years ago
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 8 years ago
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 8 years ago
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 8 years ago
maytag washer won't spin fast (Washer Repair)
by benp1 8 years ago
by lmhansgen 9 years ago
Whirlpool Washer Won't Spin, Drain or Agitate (Washer Repair)
by dsagun 9 years ago
