CDESr
#1 Posted : Thursday, July 20, 2017 1:01:54 PM(UTC)
CDESr
My Kenmore series 80 washer ceased agitating and spinning in the middle of a load. I have done enough searching to realize that the lid switch is a major culprit with this model. I have bypassed the switch completely, by jumping two wires behind the control panel. The washer will fill with water. which leads me to guess that the timer switch is operational, but this is a guess. If I turn the timer switch to any other cycle other than filling with water, nothing happens. No agitation, no spinning, no draining, and no noise at all. Which leads me to guess that the motor may be dead. Can someone please help me with troubleshooting steps for this model? Thanks!
#2 Posted : Thursday, July 20, 2017 3:41:10 PM(UTC)
In order to provide most accurate advice we need the complete model number of the washer.
CDESr
#3 Posted : Thursday, July 20, 2017 5:56:23 PM(UTC)
CDESr
110.24832200
#4 Posted : Saturday, July 22, 2017 4:08:16 PM(UTC)
You were absolutely right. A faulty lid switch is one of the most common problems with direct drive washers. The situation you described is very strange. I would recommend to order and replace the lid switch first. If it would not fix the problem, you can easily return it.
The lid switch Part number: AP6008880
CDESr
#5 Posted : Sunday, July 23, 2017 1:55:25 PM(UTC)
CDESr
Before I changed out the lid switch, I decided to try to run a full cycle, without a load. to see if it would fully fill with water and run any portion of the cycle. the washer fills and agitates but stops working after about 5 minutes of agitation. So the failure occurs at the beginning of a drain or spin cycle would begin. It seemed that I could manually select an agitation cycle, I just didn't know that the agitation section was so short, and it is also not labeled (which is why i stated in my first post that it would not agitate. I cannot manually select a spin, or drain cycle.
I replaced the lid switch, and all of the same behaviors exist. No change.
This did not surprise me, due to the fact that I had completely bypassed the lid switch by shorting the two switch wires together on the timer side. Yes, I removed my bypass once I installed the new lid switch.
#6 Posted : Sunday, July 23, 2017 7:42:10 PM(UTC)
After your last comments, the problem looks very different.
Would it do anything after you advance the timer manually?
If "Yes" then the problem is a faulty timer.
CDESr
#7 Posted : Monday, July 24, 2017 2:24:51 PM(UTC)
CDESr
No, the only things it will do is fill and agitate. If I try to manually select or advance the timing switch, it will not spin or drain.
#8 Posted : Monday, July 24, 2017 2:42:43 PM(UTC)
If it would not spin and/or drain even with the new lid switch, very likely the timer has gone bad.
The timer Part number: AP6013028
CDESr
#9 Posted : Friday, July 28, 2017 8:38:28 AM(UTC)
CDESr
I have replaced the timer, and it is still showing the same symptoms. After changing out the timer, I let it run a full cycle. It fills, agitates and then simply stops working, I cannot manually select any other spin or drain cycles. Ideas? Are there any diagnostic checks or troubleshooting steps that we can take? I'd very much like to test to find the problem rather than just changing out parts to see what happens. Is it possible to return the timer that I purchased, since it is clearly not the problem?
#10 Posted : Sunday, August 20, 2017 6:24:59 PM(UTC)
Sorry for the delay.
Check how the wires are connected to the drive motor.
If there is nothing wrong, check the drive motor windings for continuity.
Kenmore Series 80 washer problem (Washer Repair)
by sarahs 3/13/2023 5:55:33 PM(UTC)
Kenmore Series 80 Washer: small pieces of rusted metal in tub (Washer Repair)
by Guest 9/19/2021 10:28:43 PM(UTC)
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 2/5/2017 1:48:24 PM(UTC)
Kenmore Series 80 washer won't spin after drain (Washer Repair)
by dcoonce 1/4/2014 6:07:54 AM(UTC)
Kenmore Series 80 Washer - How to tell if motor is bad? (Washer Repair)
by civilclerk1 10/3/2012 3:18:52 PM(UTC)
Kenmore Series 80 Washer assembly problem (Washer Repair)
by Gabe 26 8/18/2011 2:58:45 PM(UTC)
Kenmore Series 80 Washer won't spin but will drain (Washer Repair)
by ko220 7/18/2011 3:42:54 AM(UTC)
Kenmore Series 80 Washer (Washer Repair)
by barsss 12/14/2009 9:23:35 AM(UTC)
