The inner door glass is cracked on my oven door. Is there an easy way to replace this.
There are four screws that I tried to remove but the part just did not want to come off. I did not want to damage the gasket or force anything.
I do not have a repair manual, I could use some help please
Unfortunately it is very hard to provide an accurate advise due to a non American model.
After trying to view countless websites. I looked at several brand schematics, and was able to figure things out. Turned out to me the two top screws which removed the oven back plate as well as four bottom screws, after that it was a piece of cake. Got the replacement glass from the dealer even though its not as thick as the original, it still went back together okay. Thanks again for trying
I'm glad you were able to fix it.
