jarrod40
#1 Posted : Thursday, May 25, 2017 12:44:58 PM(UTC)
jarrod40
I just replaced my HV board on my Maytag MFI2266aeq for control panel flashing and ice door constantly cycling. This fixed the flashing problem but now the water and ice do not dispense. i have reprogrammed the code in programming mode this did not help, i have also replaced the dual valve a couple of months ago so i know that is ok worked before the flashing. Is there a way to reset the control board, unplugging does not work either. Could the replacement board be bad.
