Jimdandy
#1 Posted : Monday, May 1, 2017 8:41:45 AM(UTC)
Jimdandy
I have a MAH4000AWW Maytag that has an intermittent spin cycle. The latch and wax motor were changed and the latch switch works as it should. The switch circuit tested good to the control module. The belt was changed and the motor control test was run and it passed. Also I noticed when it fails to spin the timer advances to the extra rinse cycle even when it is not selected on the switch panel. Please advise.
