cindyhott
#1 Posted : Sunday, April 23, 2017 6:14:28 PM(UTC)
cindyhott
Ice maker does not work - there is water in the door but no water entering the ice maker. This is what we have done so far:
Replaced ice maker
Replaced infared sensor boards
Replaced water inlet valve
Replaced water filter
Used hair dryer to check for frozen line - does not appear to be frozen
You can manually pore water into the ice maker and it will freeze and dump the ice into the ice bin.
You can hear the motor in the ice maker cycle but no water comes into the ice maker.
CitadelBlue
#2 Posted : Friday, April 28, 2017 5:00:09 AM(UTC)
CitadelBlue
Rank:: Member
Odd...... might want to try the control board located behind the refrigerator on the frig side behind a metal panel. Its the larger but cheaper $200 board left side when looking at it. The other is a power supply board. No guarantee but it sounds like the inlet valve isnt getting tbe signal for water. Another cause could be a broken wire that runs down the door through the bottom freezer door hinge and under the freezer. There is a connector there and one of the wires that triggers the water valve could be broken. Try reaching under there and jiggle the wire. If the wire reconnects you ll hear the psolenoid valve open and water shooting in. If this works next step is to try to figure out which wire in the bu ndle is broken. Seems to be a poor design as the wire moves everytime the door opens.
CitadelBlue
#3 Posted : Friday, April 28, 2017 5:08:33 AM(UTC)
CitadelBlue
Rank:: Member
My money is on the broken wire. That's what I discovered after a month of trouble shooting and $700+ in parts. Hope this helps. If it tours out to be the wire and you got your parts from appliance pro, they should take your parts back. Heres my experience and I havent fixed the wire yet.
http://forum.appliancepartspros.com/refrigerator-freezer-repair/569220-still-not-making-ice.html
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
