washer recently has gotten louder durning cycles the drum dosent turn freely like it once did. Is there a bearing that needs to be replaced
It could be the tub bearing, or it could be the suspension rods springs have worn out and the bottom of the transmission pulley is rubbing on the machine base when has a full load. Open the front panel, and check to see if this is the case. Also, if it was moved recently, the bottom panel could have gotten bent upwards, causing it to rub on the trans pulley. Here is a video showing that issue, it might help to look at the video for seeing if the springs are shot and it is just hanging too low https://youtu.be/UTeyWEa9LAw?lis...-XSb6kIdHFVt4tDwUgSIJ7t2Ken's Appliance Repair
