Unit has power Will not agitate or drain Set to spin only to try and drain unit Begins to rotate/ spin for about 5 seconds Then a click from panel and stops Slight humm from motor Unplugged unit waited 5 min, rotated dials Does same as above Any suggestions?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
