tt.hvacr
#1 Posted : Tuesday, March 7, 2017 3:21:56 AM(UTC)
tt.hvacr
I'M unable to find much info on the unit the fill valve opened reservoir filled water was flowing over the evaporator this unit has a drain/dump pump bottom of reservoir 3 open hole lead to a impaler where a vent tube hooks to it the tube has a factory made hole @ the u bend what happens is water leaks out the hole till the reservoir pan is empty I tried given it time to if in purge mode did not help
I believe the dump/drain pump spins keeping water from leaking out.
the Ice light is blue the Clean light is red the unit was just completely cleaned by another Tech we work on the bigger stuff thanks for the help
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3/13/2022 5:55:41 AM(UTC)
Kitchenaid Under Counter Ice Maker will not fill with water (Refrigerator & Freezer Repair)
by Macourt 1/28/2021 11:56:22 AM(UTC)
Under counter ice maker (Refrigerator & Freezer Repair)
by tt.hvacr 3/7/2017 3:21:57 AM(UTC)
KitchenAid Under Counter Ice Maker - Little Ice Being Made (Refrigerator & Freezer Repair)
by brendo234 1/27/2014 9:09:48 PM(UTC)
Is under counter ice maker grid replacement a difficult repair? (Refrigerator & Freezer Repair)
by rhondaandscott 6/19/2011 4:56:32 AM(UTC)
by ralphddavis 12/19/2010 12:49:47 PM(UTC)
Under Counter Ice Maker Will Not Go Into Icemaking Cycle (Refrigerator & Freezer Repair)
by drowe30 6/22/2008 6:39:55 AM(UTC)
