good eve my dryer will not start when i plug in the interior lite stays on hit start and just beeps i also can not acess diagnostic codes can you advise ? thanks
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
i chkd all switches --connections all chk out ok with power off you plug dryer in light comes on ---i had just changed belt and rollers dryer was workin before i took apart
I'd be checking the wiring from the door switch back. Crossed wires or shorted wires. If the switch tests OK, something else must have changed when you had it apart.
